Item
No.
Confirmation Item
Result
Notes
1. Items Related to Initialization
Item
No.
Confirmation Item
Result
Notes
Stack pointerSetting
1
Are  the  stack  pointers  set in  the usable  area and enough allowance range?Usable addresses for setting:
H -    H
Address for setting:    H -    H Max. number of nesting: Interrupt + subroutine:
YES,NO,N/A
2
Are the stack pointer values checked? Is the reading and writing check done?
Is it checked that the value written in the stack pointer is a program area of the
memory map?
YES,NO,N/A
Vector address settingSetting
3
Are the vector addresses included in the list and
the unused vector addresses set as RESET?
No. of unused vector
addresses:
YES,NO,N/A
Branch
destination
4
Doesn’t the processing logic become hang-up and an infinite loop, etc.?
YES,NO,N/A
RAM check and clearDone or undon
5
Done in all area?Execution memory area:
H -         H
YES,NO,N/A
Method
6
Are ‘1’ and ’0’ confirmed about all bits?
YES,NO,N/A
7
When an error is found, are the check/clear
repeated from the start ?
Procedure for retry:
Number of retry:
YES,NO,N/A
8
Are all the area cleared, after completion of RAM check?
YES,NO,N/A
Definition of variablesAddress for Setting, Meaning of Variables, Contents of initial value
9
After RAM check completion, are the initial values set?
YES,NO,N/A
10
Are memory addresses followed and listed in a table?Intended use:
Numeration system used : Conversion formula to physical value:
Necessary resolution: Validity of variable's capacity: Counter:Meaning of 1count: Timer:Meaning of 1count: Initial value:
Meaning of initial value:
Upper and lower limits for each variable:
YES,NO,N/A
