Agilent 二手10073C示波器探头蒋
安捷伦10073C 500MHZ探头
Bandwidth: 500 MHz System risetime (calculated): <700 ps Attenuation Ratio: 10:1 Input resistance: 2.2 MΩ (when terminated into 1 MOhm)
The Agilent 10073C passive probe is our most rugged 500 MHz probe. With a 10:1 attenuation ratio and high 2.2 M ohm input impedance, it is ideal as a general purpose, high bandwidth passive probe for the Agilent 300 MHz - 1 GHz 6000 series, 7000, 8000 and 9000 Series oscilloscopes. The probe identification feature automatically configures the oscilloscope for the probe attenuation.
The following accessories are included: retractable hook tip; orange, white, blue and green identification tags; ground bayonet, IC probing tip, adjustment tool and an alligator clip ground lead.
· Bandwidth: 500 MHz
· System risetime (calculated): <700 ps
· Attenuation Ratio: 10:1
· Input resistance: 2.2 MΩ (when terminated into 1 MOhm)
· Input capacitance: ~12 pF
· Maximum input (dc + peak ac): 500 V CAT I (mains isolated) 300 V CAT II (post receptacle mains)
· Compensation range: 6 - 15 pF谭S 135-1007-5188(微信同号)
技术咨询:蒋工135-1007-5288(微信同号)电 话:0755-21502766 传 真:0755-21502722
客 服QQ:53540923
