隔离驱动产品领先的技术优势:具有高性能、高性价比、高可靠性的产品特性,SLMi823x系列应用覆盖UPS、充电桩、服务器电源、通信电源、新能源汽车动力总成系统的车载 OBC 领域。通过CQC认证的。
隔离驱动优势:
1.管脚完全兼容光耦驱动产品并实现性能的完全超越
2.更高驱动能力,最高可达 4.0A,满足极致要求
3.更强的鲁棒性,CMTI丨输入端抗负压丨隔离电压丨浪涌电压
4.更宽的工作温度范围,从 -40℃ 到 125℃
特性:
1.1.0A峰值电源电流
2.40ns(典型)传播延迟
3.18ns(最大)脉冲宽度失真
4.18ns(最大)延迟匹配
5.100kV/us(最小)共模瞬态抗扰度(CMTI)
6.宽输入电压:3V至18V
7.高达40V的驱动器输出电压
8.输入级5V反向极性电压处理能力
9.两个驱动器之间的1500V功能隔离
10.工作温度:-40°C至+125°C
附上SLMi823x系列选型型号如下:
SLMi8230BDCG-DG SLMi8230DDCG-DG SLMi8231BDCG-DG
SLMi8231DDCG-DG SLMi8232BDCG-DG SLMi8232DDCG-DG
SLMi8233BDCG-DG SLMi8233DDCG-DG SLMi8234BDCG-DG
SLMi8234DDCG-DG SLMi8235BDCG-DG SLMi8235DDCG-DG
SLMi8233HBDCP-DG SLMi8233HDDCP-DG SLMi8234HBDCP-DG
SLMi8234HDDCP-DG SLMi8235HDDCP-DG SLMi8233HBDCG-DG
SLMi8233HDDCG-DG SLMi8234HBDCG-DG SLMi8234HDDCG-DG
SLMi8235HBDCG-DG SLMi8235HDDCG-DG SLMi8230BDCG-AQ
SLMi8230DDCG-AQ SLMi8231BDCG-AQ SLMi8231DDCG-AQ
SLMi8232BDCG-AQ SLMi8232DDCG-AQ SLMi8233BDCG-AQ
SLMi8233DDCG-AQ SLMi8234BDCG-AQ SLMi8234DDCG-AQ
SLMi8235BDCG-AQ SLMi8235DDCG-AQ SLMi8233HBDCP-AQ
SLMi8233HDDCP-AQ SLMi8234HBDCP-AQ SLMi8234HDDCP-AQ
SLMi8235HBDCP-AQ SLMi8235HDDCP-AQ SLMi8233HBDCG-AQ
SLMi8233HDDCG-AQ SLMi8234HBDCG-AQ SLMi8234HDDCG-AQ
SLMi8235HBDCG-AQ SLMi8235HDDCG-AQ
