感谢社区提供评估板学习。
板载主控芯片MM32F3277内置512KB flash,128KB SRAM,外设资源十分丰富。收到开发板照旧先做个流水灯进行测试。
首次使用需要先安装PACK和MM32-LINK驱动,这个要到官网下载。
LED和按键控制主要涉及IO初始化,代码如下:
static gpio_init_cfg_type gpio_cfg[] = { //LED {GPIOA, GPIO_Mode_Out_PP, GPIO_Speed_20MHz, 1, GPIO_Pin_15}, {GPIOB, GPIO_Mode_Out_PP, GPIO_Speed_20MHz, 1, GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5}, // uart 1 {GPIOA, GPIO_Mode_AF_PP, GPIO_Speed_50MHz, 1, GPIO_Pin_9}, {GPIOA, GPIO_Mode_IPU, GPIO_Speed_50MHz, 1, GPIO_Pin_10}, // key {GPIOB, GPIO_Mode_IPD, GPIO_Speed_20MHz, 1, GPIO_Pin_1}, {GPIOB, GPIO_Mode_IPU, GPIO_Speed_20MHz, 1, GPIO_Pin_0 | GPIO_Pin_2 | GPIO_Pin_10}, };
复制代码void bsp_gpio_init(void){ int index; RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOA, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOB, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOC, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOD, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOE, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOF, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOG, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOG, ENABLE); // JATG DIS GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_15); //Disable JTDI AF to AF15 GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_15); //Disable JTDO/TRACESWO AF to AF15 GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_15); //Disable NJRST AF to AF15 GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_15); //Disable AF Funtion AF to AF15 /*gpio cfg*/ for(index=0; index < sizeof(gpio_cfg)/sizeof(gpio_init_cfg_type);index++) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Mode = gpio_cfg[index].mode; GPIO_InitStructure.GPIO_Speed = gpio_cfg[index].speed; GPIO_InitStructure.GPIO_Pin = gpio_cfg[index].pin; GPIO_Init(gpio_cfg[index].port, &GPIO_InitStructure); if((gpio_cfg[index].mode == GPIO_Mode_Out_OD) || (gpio_cfg[index].mode == GPIO_Mode_Out_PP)) { if(gpio_cfg[index].val_init) { GPIO_SetBits(gpio_cfg[index].port, gpio_cfg[index].pin); } else { GPIO_ResetBits(gpio_cfg[index].port, gpio_cfg[index].pin); } } } // UART1 AFIO GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_7); GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_7); }
复制代码
下面附上测试工程:
