       APA150---Support multiple configurations output: • 75-W + 75-W output power at THD = 10% with RL = 4 Ω and VCC = 25.5V• 55-W + 55-W output power at THD = 10% with RL = 6 Ω and VCC = 25.5V• 1 x 110-W output power mono parallel BTL at THD = 10% with RL = 3Ω andVCC = 26V• Wide-range single-supply operation (7 - 26V) • High efficiency (η = 85%) • Four selectable, fixed gain settings of nominally 20.8 dB, 26.8 dB, 30 dBand32.8 dB• Differential inputs minimize common-mode noise• Standby and mute features• Smart protection• Thermal overload protection• Output power limited by PLIMIT function• Small offset less than 20 mV.
      APA320---Features• 160-W + 160-W output power at THD = 10% with RL = 4 Ω and VCC = 36 V• 1 x 220 W output power mono parallel BTL at THD = 10% with RL = 3 Ω andVCC = 36 V• Wide-range single-supply operation (14 - 36 V) • High efficiency (η = 85%) • Parallel BTL function using the MODE pin• Four selectable, fixed gain settings of nominally 23.8 dB, 29.8 dB, 33.3 dBand35.8 dB• Differential inputs minimize common-mode noise• Standby and mute features• Smart protection• Thermal overload protection• Small offset less than 20 mV
