采用数字电位器生成阶梯电压。在生成每个阶梯的同时产生同步信号(占空比%90~95),反向后供锯齿波产生电路。
程序很简单:rem Main.bas file generated by New Project wizard rem rem Created: 周五 5月 2022/1/28 TAOTIE rem Processor: ATmega8 rem Compiler: BASCOM-AVR简易晶体管图示仪仿真 rem Write your code here $regfile = "m8def.dat" $crystal = 8000000 Dim c As Byte '通道变量 Dim X As Byte '电阻变量 ddrd.7=1 Config Pind.7 = Output Config Pinb.2 = Output '写入控制 Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 1 Spiinit '调整各通道滑臂在下方输出电压为0v '频道0--5循环,上臂A--W电阻值由小变大 Do 'For C = 0 To 5 'c=0 For x= 0 To 250 Step 25 Pind.7 =0 Waitus 15 Pind.7 =1 Spiout X , 1 Portb.2 = 0 '写入 'Spiout c, 1 '写入通道 Spiout X , 1 '写入电阻值 Portb.2 = 1 '写入停止 Pind.7 =1 Next x 'Waitms 100 Loop End
复制代码
