前言
基于framebuffer快速对hdmi输出进行测试,以下都是直接串口终端登录开发板,使用开发板自己的编译工具链进行编译,无需交叉编译非常方便。
代码
新建fb.c
vi fb.c
输入如下内容
#include <unistd.h>
  • #include <stdlib.h>
  • #include <stdio.h>
  • #include <fcntl.h>
  • #include <linux/fb.h>
  • #include <sys/mman.h>
  • #include <sys/ioctl.h>
  • #include <stdint.h>
  • int main(int argc, char *argv[])
  •     int fbfd = 0;
  •     struct fb_var_screeninfo vinfo;
  •     unsigned long screensize = 0;
  •     unsigned long location = 0;
  •     char *fbp = 0;
  •     int x = 0, y = 0;
  •     int seg_len = 0;
  •     int tmp_seg_len = 0;
  •     int seg_num = 0;
  •     uint32_t rgb = 0;
  •     uint32_t r = 0, g = 0, b = 0;
  •     // Open the file for reading and writing
  •     fbfd = open("/dev/fb0", O_RDWR);
  •     if (!fbfd) {
  •         printf("Error: cannot open framebuffer device.\n");
  •         exit(1);
  •     printf("The framebuffer device was opened successfully.\n");
  •     // Get variable screen information
  •     if (ioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo)) {
  •         printf("Error reading variable information.\n");
  •         exit(1);
  •     printf("%dx%d, %dbpp\n", vinfo.xres, vinfo.yres, vinfo.bits_per_pixel);
  •     //if (vinfo.bits_per_pixel != 16) {
  •     //  printf("Error: not supported bits_per_pixel, it only supports 16 bit color\n");
  •     //  exit(1);
  •     // Figure out the size of the screen in bytes
  •     screensize = vinfo.xres * vinfo.yres * vinfo.bits_per_pixel/8;
  •     // Map the device to memory
  •     fbp = (char *)mmap(0, screensize, PROT_READ | PROT_WRITE, MAP_SHARED,
  •         fbfd, 0);
  •     if ((int)fbp == -1) {
  •         printf("Error: failed to map framebuffer device to memory.\n");
  •         exit(4);
  •     printf("The framebuffer device was mapped to memory successfully.\n");
  •     seg_len = vinfo.yres/6;
  • #if 1
  •     for (seg_num = 0; seg_num < 6; seg_num++) {
  •         if (seg_num == 5)
  •             tmp_seg_len = vinfo.yres - seg_len*5;
  •         else
  •             tmp_seg_len = seg_len;
  •         for (y = 0; y < tmp_seg_len; y++) {
  •             for (x = 0; x < vinfo.xres; x++) {
  •                 location = seg_num*seg_len*vinfo.xres*vinfo.bits_per_pixel/8 + (y*vinfo.xres+ x)*vinfo.bits_per_pixel/8;
  •                 switch (seg_num) {
  •                     case 0:
  •                     r = 0xff;
  •                     g = (0xff/seg_len)*y;
  •                     b = 0;
  •                     break;
  •                     case 1:
  •                     r = (0xff/seg_len)*(seg_len-y);
  •                     g = 0xff;
  •                     b = 0;
  •                     break;
  •                     case 2:
  •                     r = 0;
  •                     g = 0xff;
  •                     b = (0xff/seg_len)*y;
  •                     break;
  •                     case 3:
  •                     r = 0;
  •                     g = (0xff/seg_len)*(seg_len-y);
  •                     b = 0xff;
  •                     break;
  •                     case 4:
  •                     r =  (0xff/seg_len)*y;
  •                     g = 0;
  •                     b = 0xff;
  •                     break;
  •                     case 5:
  •                     r = 0xff;
  •                     b = (0xff/seg_len)*(seg_len-y);
  •                     g = 0;
  •                     break;
  •                     default:
  •                     printf("%s--%d:unknown seg_num %d\n", __FILE__, __LINE__);
  •                     break;
  •                 if(vinfo.bits_per_pixel == 16)
  •                     r = (r*0x1f)/0xff;
  •                     g = (g*0x3f)/0xff;
  •                     b = (b*0x1f)/0xff;
  •                     rgb = (r << 11) | (g << 5) | b;
  •                     *((uint16_t*)(fbp + location)) = rgb;
  •                 else
  •                     rgb = (r << 16) | (g << 8) | b;
  •                     *((uint32_t*)(fbp + location)) = rgb;
  •     sleep(2);
  •         if (seg_num == 5)
  •         else
  •                     case 0://grey
  •                     r = 100;
  •                     g = 100;
  •                     b = 100;
  •                     break;
  •                     case 1: //black
  •                     r = 0x00;
  •                     g = 0x00;
  •                     b = 0x00;
  •                     break;
  •                     case 2://white
  •                     r = 0xff;
  •                     g = 0xff;
  •                     b = 0xff;
  •                     break;
  •                     case 3://red
  •                     r = 0xff;
  •                     g = 0;
  •                     b = 0;
  •                     break;
  •                     case 4: //green
  •                     r =  0;
  •                     g = 0xff;
  •                     b = 0;
  •                     break;
  •                     case 5: //blue
  •                     r = 0;
  •                     g = 0;
  •                     b = 0xff;
  •                     break;
  •                     default:
  •                     break;
  •                 else
  • #endif
  • #if 1
  •     sleep(2);
  •     seg_len = vinfo.xres/6;
  •         if (seg_num == 5)
  •             tmp_seg_len = vinfo.xres - seg_len*5;
  •         else
  •         for (x = 0; x < tmp_seg_len; x++) {
  •             for (y = 0; y < vinfo.yres; y++) {
  •                 location = y*vinfo.xres*vinfo.bits_per_pixel/8 + (seg_num*seg_len + x)*vinfo.bits_per_pixel/8;
  •                     case 0:
  •                     r = 0xff;
  •                     g = (0xff/seg_len)*x;
  •                     b = 0;
  •                     break;
  •                     case 1:
  •                     r = (0xff/seg_len)*(seg_len-x);
  •                     g = 0xff;
  •                     b = 0;
  •                     break;
  •                     case 2:
  •                     r = 0;
  •                     g = 0xff;
  •                     b = (0xff/seg_len)*x;
  •                     break;
  •                     case 3:
  •                     r = 0;
  •                     g = (0xff/seg_len)*(seg_len-x);
  •                     b = 0xff;
  •                     break;
  •                     case 4:
  •                     r =  (0xff/seg_len)*x;
  •                     g = 0;
  •                     b = 0xff;
  •                     break;
  •                     case 5:
  •                     r = 0xff;
  •                     g = 0;
  •                     b = (0xff/seg_len)*(seg_len-x);
  •                     break;
  •                     default:
  •                     break;
  •                 else
  •     sleep(2);
  •     /* white black gray red green blue */
  •         if (seg_num == 5)
  •         else
  •                     case 0://grey
  •                     r = 100;
  •                     g = 100;
  •                     b = 100;
  •                     break;
  •                     case 1://black
  •                     r = 0;
  •                     g = 0;
  •                     b = 0;
  •                     break;
  •                     case 2: //white
  •                     r = 0xff;
  •                     g = 0xff;
  •                     b = 0xff;
  •                     break;
  •                     case 3://red
  •                     r = 0xff;
  •                     g = 0;
  •                     b = 0;
  •                     break;
  •                     case 4: //green
  •                     r =  0;
  •                     g = 0xff;
  •                     b = 0;
  •                     break;
  •                     case 5: //blue
  •                     r = 0;
  •                     g = 0;
  •                     b = 0xff;
  •                     break;
  •                     default:
  •                     break;
  •                 else
  • #endif
  •     munmap(fbp, screensize);
  •     close(fbfd);
  •     return 0;
  • 复制代码
    编译
    gcc -o3 fb.c -o fb
    运行
    先登录桌面wetson,桌面终端中输入init 1,关闭图形桌面
    (串口终端中输入init 5可恢复桌面)
    ./fb
    效果如下
