由于OK1028A-C这块开发板在日常的客户咨询过程中关于GPIO的复用、网口的对应关系以及TSN的相关特性问的比较多,故整理了这篇文档,以解决客户的疑问。
一、GPIO的复用以SPI复用为GPIO为例
![f_a53c9c3db0607c11c529b0ce120b9f05&t=png&o=&s=&v=1619163473.jpg f_a53c9c3db0607c11c529b0ce120b9f05&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302csfqfz8w477ws4gg.jpg)
在LS1028A.pdf中查找可以看到,1028底板上SPI_SIN可以复用为GPIO_DAT13,SPI3_SCK可复用为GPIO3_DAT14,SPI_SIN可复用为GPIO3_DAT13,SPI3_SOUT可复用为GPIO3_DAT16。
![f_8acb89238eccef12c1c6d2eb08a9b227&t=png&o=&s=&v=1619163473.jpg f_8acb89238eccef12c1c6d2eb08a9b227&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302zptonyetrjxzqz4x.jpg)
![f_a5678adb0e30ec5fee51ea5c41ee35b2&t=png&o=&s=&v=1619163473.jpg f_a5678adb0e30ec5fee51ea5c41ee35b2&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302x86so4os4yzia7o5.jpg)
在LS1028ARM.pdf中可以看到对应的RCW字段为SPI3_PMUX。
![f_daa6d912a984fb0f02f8dcb2f3a2ca6c&t=png&o=&s=&v=1619163473.jpg f_daa6d912a984fb0f02f8dcb2f3a2ca6c&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302aymxxjghuubxd0nv.jpg)
通过此图可知 ,当SPI3_PMUX=1时,引脚被配置为GPIO3_DAT[16:13],在RCW中修改后,重新编译替换烧写即可。
RCW路径:
OK1028-linux-fs/packages/firmware/rcw/ls1028ardb/R_SQPP_0x85bb/rcw_1500_gpu600.rcw
![f_b1b511df5f3ffb1c320d027cf775734b&t=png&o=&s=&v=1619163473.jpg f_b1b511df5f3ffb1c320d027cf775734b&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302otzfxyddafmak4xz.jpg)
LS028A开发板验证阶段:
root@forlinx:~#ls /sys/class/gpio
export gpiochip416 gpiochip448 gpiochip480 unexport
输入上述命令出现四组gpiochip,一般对应关系为:
Gpiochip480对应gpio1[];
Gpiochip448对应gpio2[];
Gpiochip416对应gpio3[];
若要验证单个引脚则在此基础上做加法即可,GPIO3_DATx=gpiochip416+x,
以GPIO3_DAT14为例:
root@forlinx:~#echo 430 > /sys/class/gpio/export
root@forlinx:~#echo out > /sys/class/gpio/gpio430/direction
root@forlinx:~#echo 1 > /sys/class/gpio/gpio430/value
root@forlinx:~#cat /sys/class/gpio/gpio430/value
1
root@forlinx:~#echo 0 > /sys/class/gpio/gpio430/value
同时可以量出此引脚高低电平的变化。
SPI3接口复用为GPIO时是整组复用的,当SPI3_PMUX=1时,引脚被配置为GPIO3_DAT[16:13]。
二、OK1028A-C网口对应关系![f_eb87161c75dc9660ecbbf4fb042727d6&t=png&o=&s=&v=1619163473.jpg f_eb87161c75dc9660ecbbf4fb042727d6&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302siayksc5ytlcjscb.jpg)
eno0为SGMII1G-T protocol,swp0-swp3为QSGMII1G。
1、网口switch介绍以太网系统由两个组件组成:以太网控制器(ENETC)和支持TSN的以太网交换机。
下图描述了LS1028A中的以太网子系统。
![f_991747947577b9ed7e9edf5dc814d77b&t=png&o=&s=&v=1619163473.jpg f_991747947577b9ed7e9edf5dc814d77b&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302i9szmxmzebmwbdtc.jpg)
以太网控制器ENETC是一个虚拟以太网控制器,支持GbE速度和时间敏感网络(TSN)功能。ENETC提供完全集成的GbE媒体访问控制器(MACs)。
它支持抢占和各种三层加速和卸载功能的协议,包括IP,TCP, UDP和ICMP,同时保持线速度在所有接口。
2、以太网控制器特性以太网控制器支持以下特性:
•Implements the full 802.3 specification withpreamble/SFD generation, frame padding generation, CRC generation andchecking.
•One 10/100/1000/2500 Mbit/s Ethernet port. Throughserdes, SGMII (1G/2.5G) and USXGMII (2.5G) MAC-PHY
specificationsare supported.
•One 10/100/1000 Mbit/s Ethernet port with RGMIIinteRFace.
•One 2500 Mbit/s Ethernet port connected internallyto TSN Switch for switch data transmission.
•One 1000-Mbit/s Ethernet port connected internallyto TSN Switch for switch management.
•Supports jumbo Ethernet frames with a size up to9600 bytes
•Supports double tagged VLAN frames according toIEEE 802.1Q
•Supports IEEE 802.1Qbu preemption
•PCI Express root complex integrated endpointdevice
3、TSN以太网交换机特性TSN以太网交换机提供了一组丰富的以太网交换特性,例如高级的基于TCAM的VLAN和QOS处理,以及使用基于TCAM的通用内容感知处理器(VCAP)的安全处理。
设备提供对时间敏感的组网特性,包括IEEE1588精确时间协议、时间感知整形、无缝冗余、逐流过滤和监管、抢占、切通交换等。
TSN以太网交换机支持以下特性:
•Four external 10/100/1000/2500-Mbit/s Ethernetports. Through SerDes, SGMII (1G/2.5G) and USXGMII (2.5G) MAC
PHYspecifications are supported.
•One 2500 Mbit/s Ethernet port connected internallyto ENETC for data transmission.
•One 1000 Mbit/s Ethernet port connected internallyto ENETC for management.
•One internal CPU port, for frame extraction andinjection.
•128KB of integrated shared packet memory.
•Fully nonblocking wire-speed switching performancewith weighted random early detection (WRED) for all frame sizes.
概括起来就是LS1028A最多可以引出6个网口,且都支持TSN。
![f_216f7e006c1e714bc40b309583f21368&t=png&o=&s=&v=1619163473.jpg f_216f7e006c1e714bc40b309583f21368&t=png&o=&s=&v=1619163473.jpg](https://static.assets-stash.eet-china.com/forum/202104/30/135302rqij7j38unzqwup6.jpg)
至此文章已结束,希望您通过本篇文章可以对LS1028A的ENETC、TSN交换机的特性有更深的了解。再遇到OK1028A-C开发板GPIO的复用时,可以有一定参考。
如您拿到产品的使用过程中有其他问题,可以联系我们的技术支持获取帮助。
更多关于产品信息,您可点击此处进入飞凌嵌入式官网了解。
原文链接:https://www.forlinx.com/article_view_699.html
