作者:一博科技高速先生成员 孙宜文
上期高速线生简单介绍了反射原理也提到了源端串联端接,笔者借此篇文章再深入探讨下,本文使用Sigrity Topology Explorer 17.4仿真软件。
![0e151b83f12845f396ce0c238859f60e~tplv-tt-shrink:640:0.jpg 0e151b83f12845f396ce0c238859f60e~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435z95u2a3saudkuszn.jpg)
![938da7cf57c148ed82b0a0cf81f25689~tplv-tt-shrink:640:0.jpg 938da7cf57c148ed82b0a0cf81f25689~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435du977duzrznducrn.jpg)
搭建一个简单的电路模型,给一个上升沿和下降沿均为0.5ns的脉冲波形,电压跳变为0V-2V-0V,高电平持续时间为10ns,假定芯片内部驱动17ohm,路径中传输线的时延为1ns,一起看下这个链路的接收端和发送端波形:
![f3ebb98e05dd4947bf22d4f53c2b8923~tplv-tt-shrink:640:0.jpg f3ebb98e05dd4947bf22d4f53c2b8923~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435bd9ddl9dhh35upm5.jpg)
![cd9909c0e7ed46078c4b30c8b834d533~tplv-tt-shrink:640:0.jpg cd9909c0e7ed46078c4b30c8b834d533~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435h5rik8vd4z9w58d3.jpg)
仿真结果:
![db893201a2074f65a3194de93e833e49~tplv-tt-shrink:640:0.jpg db893201a2074f65a3194de93e833e49~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435sceaxihce4cxbiea.jpg)
传输线阻抗50ohm,通道末端开路。实际电路在工作的时候,末端通常是高阻状态,也就是和开路差不多。信号到达末端全反射,每个时间阶段观测点的电压值这里就不做解释了,感兴趣的读者可以结合反射系数计算。
负载端接收到信号过冲很大,当在靠近源端的地方加上33ohm的电阻后仿真结果如下:
![cbd072ca2a6246b88d10af93bc96b7da~tplv-tt-shrink:640:0.jpg cbd072ca2a6246b88d10af93bc96b7da~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435gikzhczygbpzurhu.jpg)
![057ba3ef65594285a7f46f826782e14f~tplv-tt-shrink:640:0.jpg 057ba3ef65594285a7f46f826782e14f~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435frdnk5srqd8wuwnd.jpg)
源端阻抗得到匹配
接下来我们用实际情况做例子,模拟一个33Mbps的local bus信号,发现无端接时候的信号波形,只有一点小小的过冲,是一个还不错的信号波形。
![c2f23c8769c1465f92b0bea2044e6cc1~tplv-tt-shrink:640:0.jpg c2f23c8769c1465f92b0bea2044e6cc1~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435z8r6yawssfanavns.jpg)
但我们把速率调到200Mbps,大概是DDR1的速率,发现不端接会有很大的过冲。
![14bce0d0845d4a04b56934535311c457~tplv-tt-shrink:640:0.jpg 14bce0d0845d4a04b56934535311c457~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435w1cwlhe1lcsnfsls.jpg)
看来随着速率的提高,阻抗不匹配的链路中,源端串联还是有必要的。那么我们该如何判断何时需要端接?
这里和信号的上升时间Tr及传输线延时TD有关,下面有个经验公式可提供参考:
TD=20%Tr
我们来验证下公式,拿刚才的示例继续仿真,调整参数,上升时间是0.5ns,传输线延时是1ns,递减传输线延时,从1ns逐渐减小至0.1ns(20%Tr),观察负载端的信号质量。
![8f7171be2702427fb78faa56ddbcb4bf~tplv-tt-shrink:640:0.jpg 8f7171be2702427fb78faa56ddbcb4bf~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435kxm3svyz7zj8a3q3.jpg)
看起来,Tr减小到0.1ns的时候,反射噪声约为12%,不同的结构,不同的信号要求不同,具体看信号能容忍多大的噪声,仅作为快速定位的经验参考。另外需要注意串阻需要尽量靠近源端,不然会引起多次反射,降低端接效果,甚至导致信号更差,来看下不同位置的串阻带来的影响。
![fe1bbc0644ad4577a22ce92461158ab9~tplv-tt-shrink:640:0.jpg fe1bbc0644ad4577a22ce92461158ab9~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435pbyey0z5bqbtey95.jpg)
![c517fcd9f97c4b2a869adf4a52e5dd72~tplv-tt-shrink:640:0.jpg c517fcd9f97c4b2a869adf4a52e5dd72~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435nsuvcjlz3yjpuzrj.jpg)
文末总结下源端串联端接的优点:
源端串联通过靠近芯片发送端串联电阻,使得该串联电阻与芯片的内阻之和尽量与传输线阻抗一致。该端接简单功耗小,不会给驱动器带来额外的直流负载,只需要一个电阻就可以抑制驱动端到负载端的二次反射,常适用于点对点的拓扑上。
每周一篇技术文章,学习更多内容,请百度搜索“一博科技官网”,直接进入学习
每周一篇技术文章,学习更多内容,请关注二维码
![4a714f8275c54c798f601a48ad4d50ed~tplv-tt-shrink:640:0.jpg 4a714f8275c54c798f601a48ad4d50ed~tplv-tt-shrink:640:0.jpg](https://static.assets-stash.eet-china.com/forum/202211/22/143435qozf18of88ruyyco.jpg)
作者:一博科技 edadoc.com 高速先生成员
