串口监视器显示WiFi能连上但是ifttt.com不行 不知道为什么
代码也是跟着写的,现在不知道是哪里没写好所以不成功。
以下是试验的代码:
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include "HTTPSRedirect.h"
extern "C" {
#include "gpio.h"
extern "C" {
#include "user_interface.h"
const char* ssid = "888"; // Your WiFi SSID
const char* password = "00000000"; // Your WiFi Password
const char* api_key = "EXyB8Llx41C1Am7J******"; // Your API KEY from https://ifttt.com/maker
const char* event = "pirtrigger"; // Your IFTTT Event Name
const char* host = "maker.ifttt.com";
const int port = 443;
const char* SHA1Fingerprint="A9 81 E1 35 B3 7F 81 B9 87 9D 11 DD 48 55 43 2C 8F C3 EC 87"; // See SHA1 comment above
bool verifyCert = false; // Select false if you do NOT want SSL certificate validation
int LED = 0; // GPIO 0 (built-in LED)
int PIRpin = 2; // GPIO 14 (PIR Sensor) 连的ESP8266 D4口
int MOTION_DELAY = 15; // Delay in seconds between events to keep from flooding IFTTT & emails
bool POWER_SAVE = true; // Save power by turning off Wifi.
bool FiveVoltBat = false; // Set to true if 5V bat automatically turns off.
int loops = 0; // power save "timer"
int motionState; // cache for current motion state value
// SEND HTTPS GET TO IFTTT
void sendEvent()
powerUp(); // Turn on Wifi
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
// IFTTT does a 302 Redirect, so we need HTTPSRedirect
HTTPSRedirect client(port);
if (!client.connect(host, port)) {
Serial.println("connection failed");
return;
if (verifyCert) {
if (!client.verify(SHA1Fingerprint, host)) {
Serial.println("certificate doesn't match. will not send message.");
return;
// We now create a URI for the request
String url = "/trigger/pirtrigger/with/key/EXyB8Llx41C1Am******";
Serial.print("Requesting URL: https://");
Serial.println(host+url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
Serial.println();
Serial.println("closing connection");
// Keep from flooding IFTTT and emails from quick triggers
delay(MOTION_DELAY * 1000);
powerSave(); // Turn off Wifi
// Blink the LED
void blink() {
digitalWrite(LED, LOW);
delay(100);
digitalWrite(LED, HIGH);
delay(100);
// POWER DOWN WIFI TO SAVE BATTERY
void powerSave()
if (!POWER_SAVE) { return; }
Serial.println("going to modem sleep");
delay(100);
WiFi.forceSleepBegin(0);
delay(200);
// POWER UP WIFI TO TRANSMIT
void powerUp()
Serial.println("wake up modem");
WiFi.forceSleepWake();
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println(WiFi.localIP());
// POWER CHECK THE BATTERY
// Some 5V batteries turn off automatically
// This should keep them active
void powerCheck()
if (!FiveVoltBat) { return; }
if (loops > 30) // pulse the battery every 15 sec or so.
Serial.println("battery check");
delay(100);
delay(100);
blink();
loops = 0;
loops = loops + 1;
// INITIALIZE and Connect to WiFi
void setup() {
Serial.begin(115200);
delay(10);
// prepare PIR input pin
pinMode(PIRpin, INPUT);
digitalWrite(PIRpin, HIGH);
// prepare onboard LED
pinMode(LED, OUTPUT);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
WiFi.mode(WIFI_STA);//incread
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Blink onboard LED to signify its connected
blink();
blink();
blink();
blink();
// MAIN LOOP
void loop() {
delay(500);
// Read PIR motion sensor
int newState = digitalRead(PIRpin);
// Trigger only if state has changed from last detection
if (newState != motionState)
motionState = newState;
Serial.print("State changed: ");
Serial.println(motionState);
if (motionState == 0) // PIR sensor is normally High (1) so zero (0) means motion detected
sendEvent();
digitalWrite(LED, 1 - motionState); // LED light motion indication
powerCheck(); // Keeps battery active
/1
