这次画完原理图打算出logic,结果一直提醒我
orcap—36004“Conflicting values of part name found on different sections of “%s”. Conflicting values: “%s” “%s” Property values of “Device”,“PCB FootPrint”, “Class” and “Value” should be identical on all sections of the part.”
结果仔细查看后发现在name哪里U4A就是比U4B多一个"_4"的尾标,怎么删都删不掉,最后还是重新建了一遍原理图封装库才成功导出,所以想问一下,有没有大佬有直接修改part就能解决的办法
